Power Strokes
6.7 Aftermarket
Stand alone intercooler loop
[QUOTE="HeavyAssault, post: 1519969, member: 782"] In a way it is on it's own with a separate tstat controlled circuit. Not to mention that if you want to keep cold weather performance it might not be good to lower the intake temps much lower since diesel motors love some heat. Unless you have some serious temp issue with the output of the compressor side of the turbo I can't see what gain you would be able to quantify. While I run quite a few mods/upgrades it's hard to see intake temps that exceed 30*F over OAT on the CAC cold side while at cruising HWY speeds. Yes, as I hold higher than 10+PSI boost for a significant amount of time that delta will increase. Once the boost PSI is lower/stable IAT drops. [/QUOTE]
B
No Start help
Latest: bismic
51 minutes ago
Latest: 6.0 Tech
Yesterday at 11:12 PM
6.4 Tech
Latest: 03f3507.3
Friday at 2:11 PM
Engine and Drivetrain
Latest: ToMang07
Friday at 7:28 AM
Latest: 6.0 Tech
Wednesday at 8:24 AM
Ford Power Stroke News
tangoparson
Power Strokes
6.7 Aftermarket
