I now have the steel planetary, I think my stock 1 lasted all of 5-10mins after I swapped my hybrids in. Also, I went through suncoast for a lot of my hard parts, an I used red alto clutches. Fwiw, I'm not sure if its a tuning problem, or if my trans is letting go, but a bts is for sure in my near future cuz I'm sick of not being able to trust my trans.
The hybrids probably put you past the 350 horsepower mark.
We are product design, testing and research consultants as well as custom builders. We were part of the design team for Alto on several sets of Alto clutches for the E4OD, 4R100, 5R110 and other applications. We came up with the final design chosen to upgrade the E4OD, 4R100, 5R110, and other clutches in 2007.
Until then there were no Alto power packs made to fit the same number of clutch packs in the E4OD as the 4R100. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
By 2009-10 they should have been fully distributed.
The full 4R100 kit previously had green high energy clutches which were upgraded to a new red material.
There are and were different Alto kits available that add 1 extra clutch to just one clutch pack in E4OD, 4R100 and 5R110 transmissions. Clutches are just one improvement that can be put into a transmission and they are end users that depend on other things to work properly.
The bottom line is a custom rebuild is very different than the shelf parts that are available to individuals or local re-builders. :fordoval:
