steele86
my buddy has 01 sd with the 4r100 the issue is when he puts it 4wheel drive and turns off the overdrive the light blinks and from time to time the engine shuts down. do you guys know what would be wrong
ill have him chick again
Then either the light didn't flash and there is nothing wrong or he used the wrong tool to try and read the codes.he said there was not codes
he uses a superchips tuner to read codes. by the way the truck still has the issue the only code is the air temp (its bad), he took it auto zone they saw the same thing
