Stock 7.3 parts - Variety
Strokersace
Towanda, KS
(2) L99-03 intake "spiders" that I'll never use again. One is completely stock with an AIH plug installed, whereas the other has had the hose fittings removed and drilled/tapped for 1/8" npt. - $125 shipped EACH
2 sets of OBS motor mounts. Great shape. - $50 shipped EACH
1 set of SD motor mounts. Great shape. Includes brackets to mount to block. - $50 shipped
OBS alternator. Good shape. Removed from a 96 running motor I parted out years ago. Charged fine. - $50 shipped
OBS a/c compressor. Worked great. Removed from a 95 motor when I swapped everything to the SD setup. - $50 shipped.
OBS 1.15 a/r stock turbine housing - $35 shipped
SD .84 a/r wastegated stock turbine housing - $35 shipped
(2) SD van and OBS truck downpipe adapters. - $15 shipped EACH
94.5-03 stock 7.3 balancer. Great shape, just used. - $35 shipped
(2) OBS water pump pulleys - $15 shipped EACH
SD water pump pulley. Excellent to use on an OBS if going to an aftermarket damper. - $15 shipped
Brand new 7.3 Airtex water pump with elbow. Had on the shelf for years and won't be needing it. - $75 shipped
Thanks,
Ryan
Strokersace
Towanda, KS
Don't happen to have any SD intercooler pipes laying around do you Ryan?
I'd have to look. I think so but not sure. Have a stainless cold side that came with my irate t4 kit, but planning on holding onto it just in case I decide to sell it.
Let me poke around when I get home tonight.
ford4life76
Received spyder on Saturday. Fast shipping and very well packaged. Great guy to deal with! Thanks again!
Sent from my SM-N920V using Tapatalk
