That can vary greatly depending on the tune. Ideally, you want to see over 2600psi with a duty cycle below 50%, but with hotter tunes it is harder to see those kind of numbers, especially with a stock HPOP.
With a stock tune, you should be able to hold 2800-3000psi with a duty cycle below 50% as well.
Forgot to post some numbers.. I didn't have much time to log today but here's one that looks bad in my opinion.. i was seeing 2300-2600 at WOT with cold oil (110*) is this pump bad?
Those numbers are pretty bad, could be injector o-rings, worn injectors, oil rail plug o-rings, but being a 15 degree with quite a few miles its probably a tired hpop.
I've only had the truck 1.5yrs so I have no clue if the injectors and Hpop or originals at 257k.. I did replace the inj orings last winter. Truck seems to run ok
Called dyno proven back to see what kind of price I could get since I ordered pump and lines earlier today. Jonathan gave me a great deal on some 230/100 and took his time to discuss my options on my build. Looking forward to buying more from these guys soon
