Mwballs11
How can I tell if my heads are studded? Why would they be? And if they aren't should I?
Just underneath the valve covers on the outside you will see a nut on a stud. The studs use an allen key also for removal
Look where the head bolts would be. If there is a bolt your answer is no, if there is a stud with a nut your answer is yes. Yes you should!
if it ain't broke don't fix it
Exactly! Run her till she blows!
