03 tx pwr stroke
OK, what is the secret to get the serpentine belt off an 03 6.0? I'm trying to replace it and it appears like I have to take off the entire fan and shroud assembly. Am I just missing something simple? :fustrate:
simpliest way to remove the belt i have seen was to unbolt the alternator and tilt it towards the front of the truck to remove the belt from it. other than that im no help
Got the old one off(removed alternator). Trying to put new one on. First, had to search internet for routing diagram as the sticker on the radiator is COMPLETELY different than what I've got. Second, there is a plastic "cage" that bolts to the radiator and to the engine. Absolutely NO room for me to get my hands in there let alone the belt or a ratchet to loosen the damn tensioner. WTF Ford?
LOL guilty of doing that one
I'll add that leaving the stator off will open up the front of the motor quite a bit. Without the stator in the way belt and pulley changes are a breeze.I drained the radiator a little, moved it forward, pulled the radiator shroud, removed the fan stator, and fan shroud. Then it's really easy.
