superduty dana 60/ sterling 10.5
suprhlr
Zeeland MI
I have for sale a dana 60 front axle from a SD, 3.73 ratio. Does not have wheel bearings, steering, or track bar. Unknown mileage $600
also have a sterling 10.5 from a SD, 3.73 LS, complete minus rotors $250
I will not ship these axles, pickup only
suprhlr
Zeeland MI
it was from a std truck, but I dont think there is any difference in the axle itself, just need to bolt on a set of dually spacers
suprhlr
Zeeland MI
took the d60 apart to inspect, everything looks really good inside, bearings look good, checked the pattern/backlash on the gear, looks great. Axle u-joints were tight so I bought/installed new spicer joints, both new vacuum seals replaced, new inner tube seals, and new axle dust seals on the inner shafts.
$600, I just spent $175 on these new parts
so wish i wasnt laid off right now. i need that axle. might have missed it or forgot but whats the gear ratio?
Buck1
Winchester, IN
I'm interested. Just double checking, front has no wheel bearings/hubs correct ?
