Sway Bar Disconnect Links
footlong70
Whitecourt AB
So I've seen quite a few older threads and have been asked if sway bar disconnect links are available for our superduties. I haven't seen any and to my knowledge, nobody makes disconnect links for our years. I trail ride my superduty on occasion and can think of several times it would have been handy having a disconnect to keep all 4's on the ground or to help soften the ride. So because the links are fairly simple, it wouldn't be too hard to make from scratch. However a set of links that will bolt up without the hassle of fabbing for some guys will save them the headache while keeping a stock look. Here's what I figured:
Warrior Products makes a bunch of different size links with eyes/posts that are meant for 4 runners, explorers, jeeps. I bought a set (#83151) 12" eye to eye sway bar disconnect links meant for a CJ/Universal according to their site. The links were a little long, so a quick cut, and a quarter inch hole drilled made them prefect length. This makes it super easy for most setups.
The links will almost bolt up out of the box(with a 1/16"ish bit of slop on either side of the bolt)however, they lack the steel sleeve which is required IMO to properly torque the bolts back down and prevent premature bushing wear. So what can be done is... press the old steel sleeves out of the original links, and transfer them to the new links. If your like me you have a million of them laying around from all the shocks/lift kits bought over the years which will save a step. If a press isn't at your disposal, you can get creative with a vice too.
So before:
After:
Also I figure I should put something simple in place to hold the sway bar up while disconnected. I made a small tab and bolted it to the coil bucket on both sides for the links to pin to.
Hope this helps anybody looking for a simple upgrade for trail riding. I haven't articulated too much with them in place so I'm a bit leery of the quarter inch pins strength. However if worse comes to worse, Ill drill them out to 3/8" and use grade 8 3/8"s pins.
make sure you check brake line length. Also, never jump the truck or your shocks may not survive...
Jomax
Arizona
This, I had no swaybars, and your next thing to limit travel is the shocks, they do not survive. I HIGHLY recommend limit straps!!!
footlong70
Whitecourt AB
Um, I'm not sure what setup you guys have but the sway bar isn't designed to/or bottom out before the shocks/brakelines. Stock to every superduty lift kit I've ever installed always bottomed out shocks before brake lines and sway bars. By a lot too. The shocks ARE actually meant to be the axle limiter. But at a very low speed to prevent massive shock loading obviously. So yes mis-matched length spring/shocks and jumping is bad. Limiting straps are a great idea if either of those are factors. The higher end shocks are built with internal jounces just for that reason. However I'm not talking about baja racing here, just increased articulation/traction for slow paced trail riding...
So for sure I appreciate the points but I don't see them overly relevant to the thread.
Leftthenleft
Nc
I have though about this a lot. Looks like a clean install. I agree that those quick release pins seem a little small for our application though.
Weird. Every superduty I have had, the swaybar bottomed out before anything else. Hence the relevency to the thread...
footlong70
Whitecourt AB
Look man, I'm not trying to be a dink but I hope your not serious. The shocks should bottom out way before your sway bar does. Like way before...
But instead of just saying it, I just went out and lifted my superduty so I can take pics. I know it's not a typical setup but its the point of having a matching shock length to coil length setup regardless of lift height. Icon 7" lift coils/ with 7" Icon Lift shocks. Stock suspension is no different, it will bottom out on the shock first by alot.
So lifted by the frame with the axle free hanging:
And this is the pic of the sway bar/brakeline/shock while in free hang:
As you can see the sway bar has a very long way to go before it comes into play limiting the axle. In fact, I could put on an excessively long 10" lift shock and still not bottom out on the sway bar. All I can say is go lift any superduty (stock or properly installed lift kit) up by the frame with a 2 post lift so the axles are in free hang, and I guarantee the front axles are not being held up by the sway bar unless the shocks are removed, are wayyyyy too long for the coil height setup, or sway bar end links are wayyyy too short/swaybar drop brackets not installed or too short.
Jomax
Arizona
I should've worded myself better. The sway bar would help keep the coil in place if the shock was to snap in half. Without shocks, your coils will extend a ton more, as you probably know.
But you are right, shocks "should" be the limiting factor if everything is setup correctly.
