TBC fault need help
SmokedF747
Jersey
Just had truck studded and put in 300/100 conventionals, s366 and mpd up pipes. Now EVERY time I start the truck, I get a message TBC fault on the dash. The truck sounds like it doesnt have that inital "jump" when started, it starts slow. Dont have any issues when driving though, and it has not failed to start yet either. Anybody have any suggestions? I dont want this to be a huge issue come cold winter season.
slc dzl
Riverton, Utah
I get the same fault every time I shut the truck off in neutral in a drive threw, have never found the cause of the fault but my trailer brake works just fine.
If you find the problem definitely post it up.
SmokedF747
Jersey
Yeah it doesnt cut out fuel or anything and fuel pressure is 61 when starting, im just wondering if its starving for fuel or oil and sending a signal, throwing that code. But it leaves a check engine light, not just the tbc fault on instrument panel and code stays in edge monitor even after I clear it
SmokedF747
Jersey
Nvrm, im a moron, the code is for vgt solenoid...damn, feel like a jackarse lol but still tbc fault comes up at every start up
SmokedF747
Jersey
Alright, ill check it out when I get off my 5 days on work...12 hr shifts have their ups and downs lol
Atsah
Maine
The TBC fault normally is a wiring issue at the hitch, A bad ground is probably the issue..
SmokedF747
Jersey
Finally got it, the sensor on the bottom of the master cylinder was not plugged in fully...idk if that solves anyone elses problems, but just letting you guys know in case u ever encounter it
