Thermostats
D10Tion
California
Lookin for a low temp thermostat..only thing I've really found so far is the mishimoto 189/196 for the primary. Anyone running anything else? I'm not very familiar with the secondary cooling system but id guess it takes a thermostat to correct? I live in California where the temp can be anywhere from 15 degrees To 115 (F) in an area with a lot of long steep grades.
Mishimoto
Thanks for the interest in our thermostat! The secondary radiator does indeed utilize thermostats, which are located within the end tanks of the radiator. These are set at a much lower temperature compared to the primary system. What kind of coolant/IAT temperatures are you seeing during towing/hauling?
Thanks
-John
D10Tion
California
Thanks
-John
Hey John,
Thanks for the response! I'm seeing in the 220-228 range during towing and hauling up steep grades. Any advice and point in the right direction is much appreciated!
