Thoughts on a wastegate setup?
Jonnydime
What are your thoughts on using a small waste gate to connect the drivers side up pipe to the passenger side and then using a larger gate on the egr provision for the actual drive pressure regulation?
getstroked27
Friendship, MD
you can fabricate something like that but just using one gate. only issue is you will have to use flex couplings for the gate piping. just tube both up pipes separate, then run them into one 45mm gate.
Jonnydime
That is basically what I already have. I want to separate the up pipes completely just to be sure I'm not losing pulse energy.
Is this going on a stock or aftermarket turbo setup?
This is on my custom compounds. GT4088R fed by the GT42 style 82mm Precision from Godzilla's triple setup using an Elite vgt adapter that I modified to run the Garrett.
Jonnydime
I just figured now would be a good chance to change things up since I have the trans out.
