Sequential6.4L
- Joined
- May 19, 2011
- Messages
- 193
- Reaction score
- 0
looks like its time for a new converter/trans, took my truck out last night after it was acting normal the day before, i roll into the throttle on level ground with the TC locked an i can slip the converter to 550-650rpm before even reaching full throttle an its getting worse by the mile. Im running an ATS 5 star converter after already frying my stock one, truck basically slips an all tunes on my H&s except stock im running low end fuel on 5 with the 4th an 5th tc lock with the low shift point, the only weird thing is that i pulled the plug on the pan an changed my fluid the same day (no filter just pan fluid) so im wondering if that had something to do with it? also when my factory tc went it went slow an i was able to limp along for awhile on lower tunes, this convert just **** the bed all at once is that a possible sign of pump, or pressure issues in the tranny? im thinking a RCD converter, and getting on the horn with ATS once the thing is apart an seeing what they say about my warranty, 34,000 miles on the converter, 65k on the trans.
