slim613
- Joined
- Jan 9, 2014
- Messages
- 100
- Reaction score
- 0
2002 350 srw so new years eve i was drivin down a dirt road got back on pavement and stoped then when i went to take off again truck died and does this every time UNLESS i plant my foot on the break so my TC wont unlock i built engine/tranny several thousand miles ago
road runner "bad boy" TC
new shift solenoid when built
i checked all connections and talked to my transmission bud he said start truck disconnect solenoid plug then try it if it dies its tranny internal if it does not its electoral
so i pulled harness out tested all (while i was there) connections but payed close attention to the TCC violet with yellow trace all looked good then i went to the truck side oh harness all looked good to pcm (swapped pcm still had same issue) so went further and found my ground it trips the breaker on my power probe when i supply power
found it goin to another connector mounded with 4 others thats mounted in a row on the finder well tested that then it goes into cab
my question is where and why? what else controls it what would need to go there yes all fuses are good i got on pro demand the looked at wiring harness diagrams but see nothing and cant find anything into the cab before i tear it completely apart when i can go to one thing were it leads too or other issues it may be
