Farmrod
I've searched and have come up empty handed I'm hoping someone has all the torque specs for a headgasket job
Chris
Chris
Where did you get the manuals I'll just buy them
A lot of the older guys torque them higher then 215. I torque them to 250ft lb. Ya ARP says 215 but I've had mine fail at that. Honestly if you can do a heat cycle and check the torque would be great but that's a pain in the ars. I follow what Shawn Ellerton says, IIRC he torques his race truck to 300 maybe he'll post up. Just a theory but really doubt ARP will say 215 is max.
I know this isn't the same but somewhat the concept. In the Fire Dept our rope is rated for 9000lbs but with all our safety factors 15:1 we only put 350lbs on our rope. So there's never a chance to fail or risk. Just saying.
Any truck I work on I torque 250 and never had an issue and never came back either. Honestly I think 215 once after enough heat cycles then back off. My H-11s 8 yrs aho backed off enough where they weren't even tight anymore.
ARP even had an announcement on their site previously when the torque spec was 245, aimed at 6.0 powerstroke guys saying NOT to go above that. It's not really a safety factor, they get the torque value based on the stretch of the stud, which is based on a % of the yield. It's not really hard to figure out, but you would need to know the tensile strength and all the measurements of the stud. I still never got any answers from anyone who goes above as to WHY, other than they feel more comfortable doing it. I'm waiting for the day to see a snapped stud show up on the forums, but my guess is that if someone snaps a stud from over-torquing they're not going to post a picture of their mistake.
I could see 300 ft-lbs on one of these being dangerously close to the snapping point.
they are the OEM ford manuals it is a three set if you get the electronics manual also
it is year specific and I bought mine used from Ebay I don't know what they would cost from a dealer or if an older year would even be available ?
I would look for a set but you don't list your year
I also bought AllData the online manuals ,, not super impressed but it may also have what u need
I am with RescueF250. I torque all sets to 250ft/lb's with new lube now. The stud won't snap. I have not had bad luck with 210 ft/lbs, I used that spec when the new lube first came out, and didn't have any problems on lightly modified and stock trucks. On higher boost applications I run them up in 6 stages to 250 ft/lbs, I like having a little more clamping force. 210 is for many many uses, and is just fine for the average stock, or lightly modified 6.0. That being said, I wouldn't feel comfortable re-using a set of ARPs torqued to 250 more than 3 times.
Shawn has said it multiple times around here "250 new lube is all you need"
