Tranny problem!
6ohsuperduty
Colorado
Okay so yesterday my truck was running perfectly fine, now I have lost neutral and reverse gears. When I put it in neutral I can literally drive like it's in drive! And when I put it in reverse it will roll forward the throw us forward like I slammed on the brakes. Can anyone help me out or point me in the right direction?! I kinda need reverse haha
Atsah
Maine
Might want to PM Mark Kovalsky just in case he doesn't see your thread..
is it stock or tuned? does the fluid smell burnt at all? what happened leading up to this event?
put the stock tune on it and see if that changed anything. was the fluid changed since the issue or before. if before, how much material was in the pan and what fluid was used to refill
Mark Kovalsky
SE Florida, USA
Your problem is that the forward clutch isn't releasing. The question is why. It could be that the clutch has failed and it welded together. The solenoid could be stuck in the applied position. There could be a short in the wiring to the solenoid, keeping it applied.
Are there any codes stored?
