tranny?
slc dzl
Riverton, Utah
so my truck is acting wierd it is a 2006 f250,
Just had the tranny flushed at 62000 last week, oil changed last week to.
So there is a vibration/grinding feeling in the accelerator pedal between 1000-1200 rpm in every gear any ideas?
chappy
Marshall Mi
So you only feel it in the accelerator pedal and not the truck or seat? What about the floor if you put it on cruise and put your feet flat on he floor? just sounds more like a bad U joint . If its the truck in your avatar you should have a one piece rear driveshaft so it wouldn't be a carrier bearing.
cfdeng7
CT
I agree with chappy. Check drive train components also check and see if your down pipe is vibrating on the firewall. Mine setteled and started vibrating on the firewall around 1100 rpms. Just a thought.
Irishcream
Nanaimo B.C
I was gonna say downpipe too, had a similar sympton after going through a big puddle, turns out the downpipe got pushed up against the bell housing.
Irishcream
Nanaimo B.C
When mine was against the bell housing it was worst at around 1200 RPMs but went away so I thought I had some real problems.
