Trans or engine file problem
Jonnydime
Trans or engine file problem?
I don't know if the video I posted embedded or not but if it didn't there is a link at the bottom.
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
This is the problem I am having with my trans. If I flat foot it from a stop it will break the tires loose at the top of 1st gear then lose all boost then repeat the same thing into 3rd. It's almost like traction control but my truck did not come equipped with it.. I have the low boost fueling pretty tight so that is why there is the lag until 20psi. Ohh and don't mind the video from my potato as I still use a flip phone.
https://youtu.be/_c228kPb2-8
Jonnydime
This is with my foot flat on the floor. I am not lifting at all until the end of the video.
Jbird
Mine started doing that the second to last time i had the trans built. Turned out to be a faulty solenoid and smoked the trans.
Looks like your using h&s? Defuels?
Jonnydime
No defuels. Elite stage 5 that used to be in Colt Parker's sled pull truck.
