Transmission and Autoenginuity (AE)
Borcht Warrior
Calgary, Alberta, Canada
Hey everyone,
I got an AE kit from Dennis last year and I have used it to check my truck over every now and then.
I was wondering can you use it to check the operation of our transmissions?
I cannot seem to find any trans temps, pressures or anything like that.
Any suggestions or comments would be appreciated.
Mdub707
Mohawk NY
You should be able to do that stuff. Your only going to be able to see whatever normally comes through the OBD port obviously. I know I pulled trans codes for mine when the trans was acting up, but I had no lights or other warnings on the dash. You can definitely check trans temp, I've done that with my SCT X-2 and SCT's livelink, so AE should be able to no problem.
