Transmission help
17evanscolton
Just put a new transmission in my truck take it for a spin and it won't shift up past second gear anybody know what could be causing this?
Sent from my XT1650 using Tapatalk
CJunkie
'Murica
Did you make sure the shifter on the steering column and the gear selector on the side of the trans are selecting the same gears? You could be putting it in drive on the dash, but on the trans it's in second. That's my first thought.
Sent from my SM-J320V using Tapatalk
uncool
California
Valve body bolts over torqued causing the 2-3 shift valve to stick is the first place i would look.
