Transmission Service
vcassens
Godfrey,il
What is the best way to do it the dealer says it is not necessary to change the filter in the transmission just the inline filter and flush the fluid. What are your guys opinion on this? I am needing to get the trans serviced in the very near future just wanting to no the best way to do the job thanks Vincent
Zmann
because the filter in the pan is a screen .. the only real filter is an external filter near the radiator
the only way to service this trans is by dropping the pan and replacing the 8 ish quarts with the ford ATF or doing a hot flush from a dealer or shop that knows what they are doing
ps
Mark is our Transmission go to guy so listen to him ;-)
vcassens
Godfrey,il
I defiantly have heard good things about mark and I do trust him and will just get it done at the dealer I just wanted to make sure this sounded right because the last truck I had was a 04 with the zf6 and before that was a 95 half ton LOL but thanks for the help guys I will be getting this done soon.
vcassens
Godfrey,il
Ok so what is the best fluid to use would motor craft be the best or is there better fluid to use? thanks for the info
Zmann
Motorcraft Mercon LV replaces SP ( the original spec) but the two are mixable
valvoline Has one that is supposed to Be approved also(see high mileage ATF ) and way cheaper ,, but IDK If I would use it ?
if the dealer is doing your hot flush and filter it is $280.00 FYI
I don't know how many miles you have but I did the pan drop and filter at 30k and the heated flush at 60k
Zmann
the correct 08 up pan///// some had the same filter as us
Zmann
No worries ,, small detail
it is a great suggestion to get 100 percent filtering over the toilet paper roll part time filtering
on my list also
OBSWIZ
Wellington NV
Just a FYI..Never power flush a trans..BTS adevises never do this..just drain the pan install a new filter and refill every 30k.
For those that don't have a real filter:
Should cost less than $150
Filter #8C3Z7A098D
Pan #8C3Z7A194B
Zmann
Power flush lol
people confuse the Heated flush for power flush back flush all kinds of misconceptions
it just replaces old fluid with Heated new fluid
