JoshFulk
Ok so I just replaced 2 batteries in the truck last month. The old ones were completely dead. So I have been running just fine I go to return truck and it wouldn't do it due to low voltage. I took the batteries to be testes and they tested good. Pre startup the voltage is 11.5 then once going it will gradually reach 13.0-13.4 volts just takes a couple minutes but once I shut it down and let it sit 15-30 or try to tune it jumps back down to 11.5. Took the truck by autozone for a quick check and that guy hooked it up and done a alternator check and he thought it could be a voltage Regulator going bad or is it an Alternator?
Thanks for the help an if its the voltage Regulator where is it from the Alternator?
