I have on other vehicles that have a specific turbine inlet flange and a decent turbine wheel already.
It was nothing more than a good rebuild ($300-500 depending where you go and the quality of the balance), plus the cost of wheel, machine time for the compressor housing and/or backing plate.
The one I built for an older BMW ran $850 delivered with a coated turbine housing and billet wheel, including a 360° bearing upgrade, full balanced, and machine work. For this car, the only other wheel people have ran (aside from stock) was a 60-1 Garrett wheel. Works well but I went with a GTX3582R wheel. I took a guess as what would work better from what I have seen and examining compressor maps.
You are paying extra for the R&D of the company (Elite, RCD, etc) seeing what works best with what setups. Will a 71mm Batmowheel make more power than stock? Probably so. As much as the 71mm from Elite with the Precision wheel? Doubtful.
Would I spend the extra $500 or whatever for a known, proven, dyno'd turbocharger from one of the large companies? Yes. Knowledge is not free.
2¢
