Turbo Wheel Seized To Shaft
Ottawa, Ontario, Canada
Has anyone ever ran across a turbo wheel that was impossible to loosen? I completely removed the turbo from the truck to do a rebuild, and was unable to loosen the wheel using a screwdriver wrapped in a rag and then eventually an impact. Note that I am talking about a 99.5-03 GTP-38 without the 18mm nut on the exhaust side. Eventually I was forced to cut the wheel off after bending the shaft trying to loosen it.
The only other thing I can think of, contrary to what I've read, the wheel shouldn't be reverse thread.
From various instruction manuals;
24. Grab and hold the end of the Vise-Grip and loosen the compressor wheel by turning the ratchet counter clockwise as if removing any normal bolt.
The compressor wheel will loosen and unthread from the shaft.
Jennifer@Dieselsite
Florida
The 7.3Ls aren't reversed thread.
They're lefty loosey, righty tighty... I think it's one of the few that are like this.
EDIT - Also, why screwdriver?
