Turbo?
05chevy
Hey guys got a 06 and it keeps blowing the ic tube off at low rpm. Could the vanes be dirty and staying closed or the vane position sensor bad and making it build to much boost at low rpm or the plastic ic tube just junk? Thanks for any help
SmedingDiesel
A 6.0 can build alot of boost in the lower rpms with the stock turbo. Uses a clean rag and simple green to clean the tubes free of oil. Tighten them to the recommended 12nm and it should be fine.
