Turbo?
Pwrcummins
I don't clearly understand them. I get how they work but like the numbers I see some people post like for example ill see something like 32/45/17 or 32/46. Also what is the stock mm size of the turbo on the 6.0.
batavia,ohio
Stock from what I read is 55mm and for the numbers is the first one is the compressor wheel next is turbine wheel size and finally is exhaust housing
the chad
Yeah pretty much, then you get into a/r's as well, to make it simple a larger a/r will flow more but be more laggy, that is of course puttin it simply alot of different things affect it.
