brettboat
Has anyone ever tried twin calipers on the front disc of our trucks (all in regards to slide pin brake dana60 trucks)... IT looks like there's just enough room to shove another caliper with minimal/no outer knuckle modifications. Thinking something around the lines of a single piston GM caliper, or a wilwood narrow dynalite caliper.
Also another idea, has anyone ever machined their knuckles to accept larger calipers? Seems like if you machine out the intergle caliper casting on the knuckle you could put something a little bit larger on there. Like a wilwood GN6R is nearly the same exact length and a very similar overall displacement.
