Underboost Code!!!
CyrusLoewen
Glenn CA
A while back I swapped my 04 turbo for an 03 turbo. I bought it with broken shaft. I rebuilt it and put a billet wheel in. It seems to spool slightly faster but I can barely get it to 24psi. It will throw P0299 after I drive for a week or so. I checked the ebp line and it's clear. Just wondering if it's how the 03 wheel is or if it's a leak???
Sent from my 0PAJ5 using Tapatalk
Mesa, AZ
Does it feel at all like the turbo is sticking? Especially at a 70ish cruise and back out and then get back into it? You should check athe map hose and fitting on the intake for restrictions or cracks as well. Also if you have a way of monitoring the pressures, monitor map, ebp, and baro key on engine off. They should be pretty damn close to eachother. Spec is 1.5 psi but usually see less than .5 psi difference. Ebp sensors are pretty common, and the pigtail can get corroded throwing off the readings.
CyrusLoewen
Glenn CA
It's not sticking. But I don't have a way to monitor anything either.
Mesa, AZ
Did you check the map hose yet? I have seen that plenty of times. When you checked your ebp tube did you happen to notice the pigtail on the connector?
CyrusLoewen
Glenn CA
I replaced the map hose and as far as i remember there was nothing wrong with the ebp pigtails. Is there a way to pressure test the cac system???
Mesa, AZ
Yeah you can plug up one side completely with a rubber cone, get another one and drill into it for an air fitting and use no more han 30 psi of regulated air and dunk it in a water tank or somethin to see if you got any bubbles. This is pretty similar to what we do at the dealer. A cac leak is usually pretty noticeable though. You'll hear a constant hissing noise. How are you measuring your boost?
Mesa, AZ
Mine reads kinda low too, but i noticed i have a kink right at the back of the gauge in the line. Is something like that going on?
