Upgraded hubs
c.jank
Houston, TX
Has anybody upgraded hubs and happens to have their used oem ones laying around. Have drivers side bearing out prematurely. Tried to oil it through abs hole but no luck yet. Squeaks on left turns only.
sagebel
East Chatham, NY
I upgraded to the Solid Axle FreeSpyn kit on my 2000 and it worked great. You get a premium hub and serviceable bearings. Dynatrac also makes a kit but I'm not sure either company makes a kit for the newer trucks yet.
c.jank
Houston, TX
Yea theres no reason mine should be failing at 60k.. my gues is the cheap level kit that was on it before me and rough oilfield roads from the previous owner are a bad combo.. probably just gonna go stock again
