Powerstroke Man 6.4
- Joined
- Jan 10, 2012
- Messages
- 4,037
- Reaction score
- 3
So I got a buddy has a 2000 F-350 CCSB DRW Lariat LE (Yes LE) 175,000 miles. He called me last night and told me that the truck was misfiring barely could move at WOT. I told him to pull codes sent me this codes P1391/P1393 /P1316/P1211. So this morning went down to his house started the truck started normal/normal idle. Hooked up AE pulled the same codes cleared the codes checked oil level. Checked ICP 650 PSI at 12% IPR DC at idle shut it off. Ran a buzz test both banks test sound strong but passenger was weaker than the driverside. Started it still idling normal and ran a CCT Came up with cylinder #8 code (which is common for the grey CPS) Tried to take it for a drive 50 FT down the road ICP/DC was normal then it immediately started misfiring (still normal ICP/DC) no power at WOT could barely move. Checked codes again no codes other than P1316. Parked it immediately pulled the valve covers checked driverside first. UVCH on the driverside was tight no burnt pins checked out good. Pulled every injector electrical connector one by one checked out good. Then we pulled the passenger side VC checked the UVCH. Clip was hanging and it was loose. No burnt pins but inside the connector was soaked in oil (first time I seen oil in a UVCH connector). We immediately ordered parts from ford.
2 VC Gaskets
2 UCVH
New CPS (Just to eliminate any problems with the CPS even though there is no code just for peace of mind)
New GPR
Every time we turn the KOEO the GPR throws a little spark. Anybody know what causing that. Thinking its bad but is that's whats causing the truck to throw the 1391 and 1393 codes? (Truck starts up easy no problems starting up hot or cold WTS light works as normal,batteries are new battery voltage is normal.)
Going to pick up the parts in the morning.
What you folks think really hope the UVCH's and VC GPR, CPS etc fixes the problem. He has to tow his excavator on Thursday. Thanks fellas sorry for the long post. All help/suggestions are welcome.
2 VC Gaskets
2 UCVH
New GPR
