cbuttre835
- Joined
- Jun 5, 2011
- Messages
- 172
- Reaction score
- 0
Well I've been back and forth on this Dana 60 swap, about whether to do an RSK, if so - which one; or just stay with the factory shackles in the front and OBS length springs. I have an intercooler mounted (but not plumbed :doh
and so that might complicate an RSK.
If I use the 2200 lb capacity OBS F-350 springs, and just roll the 60 under the truck; how much lift will I gain?
I should be able to use the factory track bar that came with the donor axle, too, correct? And factory track bar bracket... and run a sway bar... and not have to worry about front driveshaft length...
Ride is of some concern; I understand the RSK and longer SD springs will ride much better... and I like the idea of the PMF RSK 2.25" lift kit. But I don't want the truck down for a whole weekend, I don't have a heavy welder at home (just a little 120V MIG) to do it up right; so it'd have to be done elsewhere...
And it's quite a few bones less to just swap in the 43-516 springs...
Those who have used OBS F-350 springs, would ya do it again?
