Valvespring recommendations ?
JD3020
Farmersville/Dayton, Oh
Shimmed 910's here, so far so good. I paid $140ish for a micrometer, springs, and complete shim kit.
But whenever i do headstuds i may yank them out and try to find a set of bee-hives.
Turbo Man
Marseilles IL.
Shimmed 910's do sound like the way to go from what I have read. It looks like the spring compressor tool and micrometer will cost me more than the springs and shims. I have 230k on my truck, would it be a good idea to replace the valve seals at the same time?
KBMKVIII
Texas
Yes. Cheap to do so why not.
MossBack
UTAH
Yes do seals because the shim goes under it... I bought a $10 harbor freight valve spring compressor welded a nut to the top. And it did the job and only popped off once and I lost keepers...might as well consider pushrods too.... For another $225 you can have swamps rods in there and you have to remove the rocker anyways...
Turbo Man
Marseilles IL.
Thanks for the input. I have been reading some installation write ups. Why is it that some instructions tell you to remove the injectors and some don't? I really don't want to remove my injectors if I don't have to. If I remove the injectors I will need new o rings and copper washers. That's money and time that can be put into something else.
MossBack
UTAH
For more room to get the valve spring compressor on the spring. For me I sent out my injectors to be built into 180/100 so I had about a week to do mine.
