Myerswelder
I studded my truck about a year ago and used Victor Reinz gaskets that look just like the factory ford along with ARPs. I sent the heads off and had them machined, cram checked etc. I changed the oil cooler with a factory ford and my truck was already ******d. Long story short my truck is puking coolant again after about 25k miles. Is it a common thing that these are failing? I'm getting ready to pull the heads off to have them checked out and more than likely gonna get o-ringed. I'm gonna use factory ford gaskets this time as well. Can I re-use my ARPs or should I spend another 450 on a set? Any advice input would be greatly appreciated. FWIW my truck is all stock besides custom tunes and air intake. It's getting ready to get a 68, thumper 2, and injectors so I wanna get this head gasket issue solved too :fustrate:
