water pump question
turbofox54
yorkown va
I'm doin headgaskets and studs and other upgrades and want to replace the water pump while its apart. I have an 03 build motor and was trying to get some opinions on if it is worthwhile to swap to the newer front cover to run the bigger 04+ water pump.
java
Texas
I'm not sure if it'll be worthwhile but whatever you decide put a bullet proof water pump.
turbofox54
yorkown va
That was my plan.....just didnt know if the 100mm vs 90mm impeller is worth the hassle of changing the cover. I have not had any cooling issues before and now the egr is going to be out of the system.
05wh250
hendersonville, nc
If you haven't had problems i would just leave it, just make sure there aren't any signs of cavitation when you pull the pump out
