Nic
i know it could be a number of things..chaffed wiring harness, hpop, ipr valve etc, but has anuone else had this problem and had the issue adressed? WHAT WAS IT???
no matter if the truck is cold or hot, ever since i bought it in 09, it has done this..since then ive had all the work done and it STILL does it.
sometimes she fires right up on the first turn, others it takes LONGGG crank times..others it fires over first turn but chuggs up to an idle and lastly some times it cranks forever and then chuggs up to an idle....never the same. seems to start better in a hot tune though. ???
