Weird whine on take off
scorpion67
BUTTE CITY, CALIFORNIA
As thr title states my 2006 6.0 has done this off and on now for last 4 or 5 months.. when i take off about half to wot it'll make a weird whining under the dash.. for lack of better description it kinda sounds like low pitched supercharger but it dusnt following the rpms like a bad sterring pump our 7.3 likes to do that its not like that, it stays the same untill jst before it shuts off it crescendos then quits.. a lot a the time if i hit the brake good it will quit making the noise.
Does a bad degas bottle cap make strange noises when its junk?
Could it be ABS module because my brakes have been acting goofy for few months to. somtimes the pedal will be firm then all of a sudden fall away and catch again closer to the firewall... its really strange never loose brakes i just don't really like it..
Thanks ahead!!
webb06
Seneca, MO
Maybe power steering pump? That would affect braking as well. Try taking the belt off for just a second and see if it still does it.
scorpion67
I could do that but the problem is it only makes that noise when im under a load, it does sound like a tensioner or fan clutch isnt liking life when its hot in the summer and im towing.. Again our 7.3 did/does make that noise too. I'll have to keep trying to track them down.. btw only 76 or 77k miles on the 6L
scorpion67
Ya theyve been done actually under warranty they made us buy the studs but thats not bad at considering the warranty co. lost $3800 over it haha and the vanes stuck on the way home from the dealer with 47k on it! 6L keep ya on ur feet but they sure are fun!!
webb06
Seneca, MO
Try replacing the coolant tank cap if you think it's leaking causing the whining
scorpion67
ok i think il do that because it will leak and every now and again when i if i run fill it up to where its suposta be and run it hard. don't know if i really trust the dealerships headgasket job:-( What are the options for remote mount degas bottles?
