speedracer1000
obviously a broken reservoir screen but i jus did a bunch of work to this 04 my buddy bought it needed hg's so we hauled it in and tore into it doin studs egr delete new stock injectors, and i replaced the oil cooler and screen while i was in there, so i kinda got that ruled out, but ever since i first got it runnin its always had a icp too low code in it, guy drove it for prob a month it ran perfect, then the hpop went out, replaced it, drove it 5 days and it went out again, so i put another one in it and it runs perfect for now, been drivin it a few days but i still got that code, i hooked my scanner on it and it wont match desired icp any higher than 3500. it usually maxes the regulator at 85% at around 3/4 throttle or 3000 psi it fluxuates a little bit but wen the desired icp is 4000 it wont match it, it hangs in the mid 3k area. also at idle icp reg is at 23% at 580 psi. i suspect no leaks cuz wen hot or cold it starts right up. jus an assumption of course, any idea wuts goin in with this thing? i should mention it has the sct canned street tune on it. ive done a pile of work on 6.0s so they arent new to me, jus cant quite figure this one out
