I am tearing my truck down again to go bigger. I'm currently running out of oil pressure with my injectors and hoping to find a good pump set up. Should I run my stock hpop with an external helper or what? Any advice would be helpful.
If your gonna tear it down anyway...if the cab is off it's easy to swing the motor out, pull the rear cover and change the branch tubes to the 05 style and run a thumper...or pull the motor if the cab isn't off and change over...then throw a cam in while you're there, if you don't have one already.
