roustabout04
Ok so I'm gonna end up pulling these last 3 hairs out. I've had an annoying whine and have had it almost 2 months and can't figure out the cause or location. Heres what I got:
It's not in the front or rear end.
It's not a u joint or swing bearing.
The up pipes arent leaking.
The noise get louder as my turbo boosts and drops as my boost drops.
It only does it when in gear. Even if I put it in 4wd and do a stall like I'm about to launch.
It seems to change pitch and tone with engine rpm especially from 1700-2200 rpm.
If I'm going down the road and put it in neutral it and rev up it doesnt do it.
I've changed tranny fluid and both filters. The fluid was clean as the new fluid I replaced it with.
I've changed front and rear diffs fluid.
Changed u joints and swing bearing.
Boost isn't affected. Power isn't affected. Fuel mileage isn't affected. It's not the tires.
If I let off the throttle it goes away. It only whines under load while in gear. Even when taking off it does it.
It's not the power steering pump or idler pulley or anything that's belts driven.
I'm at whits end. PLEASE HELP!!!
