MrOneEyedBoh
- Joined
- Feb 24, 2013
- Messages
- 799
- Reaction score
- 0
So Ive been chasing a clunk as most of the regulars know ( and seen my threads ) Turns out that the overload spring is hitting the rear bumper pad. Here is a little history:
I had just bought the truck about 2 months ago with 36k on the clock, and never thought to check the bed out before buying it. The truck came with a new drop in bed liner that I planned on removing and having a spray in installed. I pulled it up yesterday and seen there was a 5th wheel installed at some point. That lead me to second guess the leafs as a potential clunk
So yesterday I went to look around again and trying to find out where the clunk was originating from. So I put some grease on the overload spring and sure enough, contact... Whats weird is that if I hit a bump on the highway, I dont really get anything at all, then I hit a dip on the highway and I can here the clunk noise, drivers side rear. Or hell something as small as a speed bump, I can hear it. Most people on the forums were telling me end links, and this is the symptoms too. But everything is super tight, rubber wise.
Now here are my questions:
1. Being that this has a 5th wheel installed could this mean my springs are sagged and causing the overloads to contact?
2. I attached a picture so you can see the distance. Is the distance correct, it seems pretty close unloaded to me. Both sides look the same in the rear and the fronts have more of a gap, around 5-6".
3.Could the leafs be sagged, hence the reason its so damn close from the overload springs to the rubber bumper? Any way to check, possibly measure wheel wells?
4. I also read a few people experience the same clunk noise unloaded like I am ( while hitting certain bumps ).
Here are a few updates with pictures...
I aired up the tires to both 65 psi and took the best centered measurement I could.. Odd thing is, Im having an issue on the drivers side, but the passengers side is lower lol..
Here are some pictures of the measurements and the gaps on the leafs.
