What is the typical 4R100 TC lockup strategy for a drag file? is it locked the whole time after the 1-2 shift or does it unlock at the gear change? Still understanding these autos...
You guys using a PCS or tuning the PCM?
Not to derail , but what would be the harm in a lockup at 50% throttle or more ? I have a semi built trans and tc and always wait for lockup @35 mph before full throttle for fear of destroying my tc.. I guess my question is why not lock the tc at any throttle pos after the 1-2
sent while looking at a hole in my block
The only downside of the PCS is the lack of control on TC lockup. Its only done off MPH, I wish there was a parameter for WOT so you could delay it and be more exact vs guessing what RPM/MPH you will be at.
FWIW I usually lock in 2nd at 13-16 MPH
I could be wrong, but Im not sure I have any lock in 2nd right now with any of the tunes. For street driving its great, but it blows through the 1-2 and 2-3 in a drag scenario and doesnt really pull until into 3rd/locked. I expect ET is off .20-.25 and a 2-3 mph in 1/8 due to this.
Are you locking right after the 1-2 (noted by bigr) or are you delaying a little (as Curtis said)? I was planning to let the tuner make the call, but wondered how much everyone varies on this.
Not the answer anyone is looking for, but this is the reason I wired in a manual lock up switch. With a little practice I just lock mine as soon as I go WOT racing, and everyday driving I lock it when I want.
To some its probably a pain, but it doesn't bother me flipping the switch.
Hows that new setup run?
