wrecked 96 f350 drw, no motor or trans
78f100
Bonifay FL
I have a 96 2wd f350 xl that was wrecked in the front end. I used the motor and trans in a swap so everything for a zf swap and the engine are gone. The cab appears to be ok but it is tweaked. Has a pretty good gap between the cab and bed on the driver side and is close on the passenger side, It took a pretty good lick on the front clip. I have not verified if its just the frame or if the cab is actually bent. Drivers door is bent pretty bad. The bed is in good shape, both fenders have small cracks but are not seperated and have no pieces missing. The po removed the front fuel tank. The truck was in great shape before the wreck. I believe the frame could be straightened but not sure.
Basically it has a pretty good cab, bed, and rearend. I need to get it out of my yard. It will come with the (trashed) front clip if its wanted, It has been removed. I have a title for it also.
I would be willing to deliver it if someone wanted to pay for fuel and a little of my time.
I would rather someone get some use out of it rather than scrap it, there are some good parts left.
Make me a offer.
Text are best 850-768-2541, or pm me.
Snowman269
DL, MN
I don't know where to start, but I have an F700 that needs what you have left. Distance is a problem, but I am interested. What are you thinking for the whole thing? Thanks Dennis
bluedge8
Champlin MN
Damn! you have got to win for having the most BTS transmissions!!
