WTB: 4R100 2wd transmission
4duggan
Bloodymore , Murdaland
You in a hurry ? I am converting my 450 to 4wd , only need to decide if a BTS is warranted for my conversion.
Otherwise I am going to go with 4R100 HD , which will be alot sooner.
Truck has 79k on it . So may be a little bit better than a core.
yotaneck13
I have a 4wd core. I believe the valve body went out on it. Fluid was clean when I drained it. The pan had a bunch of plastic/metal in it. No foward or reverse gears. I'm located in western Pa.
