Wtb: 7.3 longblock or complete
97f350stroker
Burgettstown pa
Need a motor for my obs looking for a forged rod motor either complete or longblock. Must be ready to run and good compression not needing a rebuild.
97f350stroker
Burgettstown pa
Take it you broke something?
Well the motor decided to mix all the coolant and oil along with pushing it all through the rad and and cooking system. Thought it may have have been a oil cooler but compression numbers were junk. Plus with the way the oil looked I figured my bearings were wiped out anyway.
Where are you located?
Burgettstown pa. About 15 mins west of pittsburgh
97f350stroker
Burgettstown pa
I have a 96 F-250 Powerstroke that I'm parting out. I'm right on the KY, VA, WV border.
http://www.powerstrokearmy.com/forums/showthread.php?t=72105
Engine has 185k on ran like a champ at the time I decided to part it out.
If you're interested,.....just let me know.
That's like a 5 hour haul for me I'm hoping to find one a little closer but I'll definitely keep you in mind. How much for the long block?
I'm in northern wv.... I have two long blocks, turbo to pan but I'm not sure on the history of either.
I need to know running condition, I have another motor sitting here that needs rebuilt so I don't want to buy another that may be in the same condition.
Clouse2411
Bascom, Ohio
I have one, just missing the following - turbo, injectors, hpop, and fuel system. Had 280,000ish on it but always started right up and ran with no problems. $400. Text is best 567-230-2474
97f350stroker
Burgettstown pa
Any idea on compression numbers? Good price I'm just a little hesitant of the miles since I'll be throwing 230/200's and a s468 at it
