WTB: Stock 7.3 turbo setup
Big Calo
I need a complete turbo setup. I have a Early 99 block with the manifolds, so if you have a E99 setup I will need up-pipes, pedistal, and turbo.
If its a 99.5-03 I will need up-pipes, pedistal, turbo, spider pipe, and intake plenums, and maybe the manifolds. I'm trying to find out for sure on the manifolds.
If you have any of these things let me know, and maybe I can at least piece it together. Thanks.
Cr500
I have complete early 99 stuff, or late if you rather want that.
As far as exhaust manifolds go, driver side 94-97 same, 99-03 same. Passenger, 94-03 same.
Big Calo
Just to clarify, there is no difference in early to late 99 manifolds then either side?
chris1978
Kamloops BC Canada
L99 and E99 manifolds are the same. When I did my conversion the L99 uppipes bolted right in.
Also I have a E99 pedestal if you want it.
