chris89
- Joined
- Aug 25, 2011
- Messages
- 170
- Reaction score
- 0
Why kind of hp/tq can these transmissions hold up to and what are there for upgrades?
Yeah my third gear shift has the be just right but I'm starting to get it figured out. Is there any way to prevent the tail shaft problem?
Id spend money upgrading something else first.
I talked to the boys at Midwest.....
In order of importance they listed:
Clutch, obviously
Auxiliary cooler- think big automatic tranny cooler
Input shaft
Dan offers a input from a 6.0 six speed, because of the bigger(roller) pilot bearing
Output shaft, which is involved if you have a 4x4
I asked him about cryo treating the shafts, and Dan seemed to think it wasn't really necessary.
I understood him to say that his personal experience involved an approx 800 hp Chevy setup???
At a little over 200k, mine shifts nicely, however it has started to howl at light load state, so I'm sure there is a bearing dying a painful death. Also, at the last fluid change I could feel a hard part in the bottom of the case. Also, a 1/4" diameter spring laying in the bottom?? No idea where that's from! But it isn't right, obviously.
I was changing trans fluid approximately once a year, and its always black, so heat is a big issue. This truck is routinely hooked to 14k, and sometimes a lot more, with only slightly higher than stock power, maybe 300 hp.
