02 f-350 rear spring swap question
tgf
southwest mo
I picked up a set of cab and chassis rear springs(11 leaf + overload) the other day to replace my shot 5 leaf + overload spring pack. My stock suspensions block had the bump stop built in. The cab and chassis springs didnt have a bump stop.
Do i need to have a bump stop with this set up in the form of a block or do i need to get a longer stock block?
tgf
southwest mo
My parts guy at Ford said there are 3 rear spring set ups, 2wd uses no block, f-250 4wd uses a 2 inch block and the f-350 uses a 4 inch block. FWIW
tgf
southwest mo
Spring width for f-250 and f-350 are all the same number of leaves are the only difference. I also noticed that the nub on the overload spacer are different between the cab and chassis and 1ton.
ncollins64
winchester springs, tn
If I'm not mistaking, isn't the cab and chassis springs shorter by a few inches. I know on the 08 and up models they are. Maybe someone can clarify
