AirFishAutomotive
putting 05 wheels on a 2000 truck, I know that the offset is different on them but what is the correct size spacer needed so they will look correct on the truck ?
i think the correct is 1.25" but in order to put that small of a spacer on you have to either swap the studs for shorter ones or cut them. I put some 05 wheels on a 03 last week with 2" spacers and i think they look better then the factory offset, they are perfectly flush with the body now.
