Strictly Diesel
OK, I've been all over the internet and searched this forum and others looking for pictures and information to confirm the wheel size and offset/backspacing to get the look I'm after.
From what I can tell, the 08+ 2WD trucks all have the same suspensions and track widths. I will be lowering the truck (typical 3/5 drop). Call me picky (I've been called worse), but I do NOT want the tires on the truck to stick out noticeably, it's just not my style. I would like for them to end up right at flush with the fender lips (front and rear).
The wheel I like the most is 20x9 with a +10mm offset (5.39" backspace). I'm afraid that's not enough and it will stick out more than I want. If I'm seeing right, Daves truck (http://powerstrokearmy.com/forums/showpost.php?p=484769&postcount=7) has a +18mm offset (front 20x9) and still sticks out slightly. The +10mm I'm looking at will stick out more if I understand correctly.
So, if I can find one, I'm probably looking for something with more than +18mm offset.
To compound this issue, I don't care for all of the fake bolt heads, fake beadlock, and other similar features that make most wheels look like they were designed for 4x4 trucks only. I prefer a smooth, "sport truck" looking wheel. Unfortunately, the choices are limited in 8-Lug configurations.
So...here are my questions:
1. If I get (4) wheels with the same offset, will they sit the same at the fender lip...or is the front and rear track width different?
2. Has anyone with an 08+ found a 9" wide wheel with an offset that fits flush (or very very close) at the fender? If so, what was the offset and who makes the wheel?
3. Any suggestions for wheels that fit what I'm looking for...or for companies that do custom wheels/offsets for 8-lug trucks?
4. Any pictures of an 08+ 2WD (lowered or stock) that I may not have seen in the other threads on this site?
Thanks guys!
Thanks guys!
