Peroni
I'm looking for an upgraded pinion yoke to fit the long spline 10.25 Ford axle, takes a 1410 series ujoint and uses ubolts. I can find them that use straps but my personal preference is ubolts.
The only one I've found is a Nitro Gear & Axle part # YOKF100605-UB. Has anyone had experience with Nitro pinion yokes?
Another option is to buy the Ford yoke, plug the bolt holes and mill out new ones for the ubolts. The hole pattern is narrower for the ubolts so it's not like more material is being removed further out on the ears. I can handle the machine work no problem.
Cost between the Nitro and Ford part are almost even.
Are there any other options out there?
